bansman76 Posted December 21, 2010 Report Posted December 21, 2010 hello guys. 97 shee. was told on stock bore with fresh rings. pro circuit pipes toomey 2 -1 filter 13-41 gearing as far as i know everything esle is stock 120 lbs compression in left cylinder..125 in right cylinder.. my questions are ..1 should i continue to run the toomey 2-1 air filter or get a stock airbox without lid ? 2 the compression is pretty good ? dont know the sea level or jetting at this time but do know its jetted pretty rich by looking at plugs.. i live in central ky and mostly trail ride with some fun hill climbs around here and visit tennessee and southern ky often.. thanks in advance for all the info Quote
Jereme6655 Posted December 21, 2010 Report Posted December 21, 2010 the filter all depends on what you typically ride in......the stock airbox is pretty good at blocking alot of things/dirt from entering your engine.....however it is also pretty damn restrictive. Quote
