Chase624 Posted December 20, 2010 Report Posted December 20, 2010 (edited) I got a 03 banshee with paul turner high rev pipes, prodesigns cool head with 19cc domes,k&n filter, boost bottle, And a Ricky stator adjustable timing plate set at + 4 degrees and where I live the altitude is 4800 feet and I was wondering what jets should I use ??? Edited December 20, 2010 by Chase624 Quote
06specialedition Posted December 20, 2010 Report Posted December 20, 2010 I got a 03 banshee with paul turner high rev pipes, prodesigns cool head with 19cc domes,k&n filter, boost bottle, And a Ricky stator adjustable timing plate set at + 4 degrees and where I live the altitude is 4800 feet and I was wondering what jets should I use ??? I'm assuming stock carbs..... I would start at 290 mains, stock pilots, needles on middle clip, 1 1/2 turns out on air screws. You will probably be rich on the mains, but work your way down from there. I'm at 5000FT, so that should get you fairly close. Quote
Chase624 Posted December 21, 2010 Author Report Posted December 21, 2010 I'm assuming stock carbs..... I would start at 290 mains, stock pilots, needles on middle clip, 1 1/2 turns out on air screws. You will probably be rich on the mains, but work your way down from there. I'm at 5000FT, so that should get you fairly close. Well I'm running kinda a lean mixture of 36:1 yama lube I'm not sure if I should change that too Quote
CraigP Posted December 21, 2010 Report Posted December 21, 2010 Well I'm running kinda a lean mixture of 36:1 yama lube I'm not sure if I should change that too I run a 32:1 ratio Quote
rdzbangshee Posted December 21, 2010 Report Posted December 21, 2010 you should run it a little fat on jetting enough to just feather the clutch but i run a duel taper needle on the 4th clip rich and crisp top end Quote
06specialedition Posted December 21, 2010 Report Posted December 21, 2010 Well I'm running kinda a lean mixture of 36:1 yama lube I'm not sure if I should change that too I've always ran 40:1. But 36:1 is richer than 40:1 Quote
