1998BansheeLover Posted December 7, 2010 Report Posted December 7, 2010 hey guys, i was wondering if can i run a 115 long rod with cheetah cubs?...or not?...and also i have another banshee im thinking of running a 4mil crank in wats a good brand to run? Quote
Blewbyu Posted December 7, 2010 Report Posted December 7, 2010 That is the recommended rod length for the cubs, use blaster style pistons and everything lines up. No need to get it ported. Quote
Blewbyu Posted December 7, 2010 Report Posted December 7, 2010 Not a problem, just here to help, lol. Quote
jbooker82 Posted December 9, 2010 Report Posted December 9, 2010 That is the recommended rod length for the cubs, use blaster style pistons and everything lines up. No need to get it ported. I guess it depends on if he is running a stock stroke cub cylinder now and wanting to up grade or if he is starting out fresh with all new parts. Quote
Blewbyu Posted December 9, 2010 Report Posted December 9, 2010 I guess it depends on if he is running a stock stroke cub cylinder now and wanting to up grade or if he is starting out fresh with all new parts. That is why he will have to buy the correct pistons, which will change the location of his pin height, blaster style for the 115, and regular pin height for the stock(110)rod. Quote
jbooker82 Posted December 10, 2010 Report Posted December 10, 2010 That is why he will have to buy the correct pistons, which will change the location of his pin height, blaster style for the 115, and regular pin height for the stock(110)rod. Yea I mis read the post. I was thinking stock crank to 4mill long rod. Quote
