hotrodbanshee Posted November 30, 2010 Report Posted November 30, 2010 Should I go with K/N pods and outerwears or toomey's 2 into 1 filter setup with outerwears? Any performance difference between the two? Quote
06specialedition Posted November 30, 2010 Report Posted November 30, 2010 Should I go with K/N pods and outerwears or toomey's 2 into 1 filter setup with outerwears? Any performance difference between the two? If you stay out of large water puddles, pods are the only way to go IMO. I ride 100% dunes and have never had an issue with pods. Quote
banshee67 Posted November 30, 2010 Report Posted November 30, 2010 TOOMEY ALL THE WAY!!!! people say that they are heavy and cause the boots to crack. i just think that all that is BS. i like them and we used them on one of our bikes for years and only replaced it because we finally got rid of the stock carbs and it wouldn't fit the bigger carbs Quote
bansheesandrider Posted December 1, 2010 Report Posted December 1, 2010 I use the 2 into 1 filter on all my Banshees, with a K&N element and an Outerwear on it. I did not notice a difference in power when I switched to it from pods, but when I made the switch I had a pretty mild build also. I switched because with 3 Banshees and a Blaster, it was too many filters to clean. I have never had a problem with cracked boot on the 4 different Banshees I have had a 2 into 1 filter on over the 21 years I have had Banshees. Quote
mysterion Posted December 1, 2010 Report Posted December 1, 2010 I have the Toomey 2:1 and have had no problems. You might have to zip tie it to keep from burning a hole in the outerwear. Quote
bansheesandrider Posted December 3, 2010 Report Posted December 3, 2010 I have the Toomey 2:1 and have had no problems. You might have to zip tie it to keep from burning a hole in the outerwear. You should be able to rotate the filter on the 2 into 1 adapter so it clears your pipes. Quote
hotrodbanshee Posted December 3, 2010 Author Report Posted December 3, 2010 Going with pods/outerwears 60.00 shipped. Quote
boise_banshee Posted December 4, 2010 Report Posted December 4, 2010 60.00 shipped???? Where at? Help a brotha out. Quote
