quick question
NOVIS
im removing my coolant overflow bottle. i ran a new overflow tube, took out the bottle and took out everyting else that didnt need to be there. the one hose ran from the bottle, then had a T joint and one side went to an overflow that just drained out and the other side went under the plastic cover on the clutch side. just wondering what i should do with it. im thinking i should cut and plug it but im not sure.
um, lol...yah that's one of the 2 case vents..........it shoud be T'd to the rear vent, and the line going up by the rad, so water doesn't get in there. you can just plug that one if you really want. my dd cover doesn't even have one there. do not mix them up with the coolant hoses...
