NOVIS Posted November 23, 2010 Report Posted November 23, 2010 im removing my coolant overflow bottle. i ran a new overflow tube, took out the bottle and took out everyting else that didnt need to be there. the one hose ran from the bottle, then had a T joint and one side went to an overflow that just drained out and the other side went under the plastic cover on the clutch side. just wondering what i should do with it. im thinking i should cut and plug it but im not sure. Quote
NOVIS Posted November 23, 2010 Author Report Posted November 23, 2010 oh, its another overflow for the bottom end oil. i just plugged it. if i get some longer hose ill run it another overflow tube to the back, Quote
Larry's Shee Posted November 23, 2010 Report Posted November 23, 2010 On my son's that hose and one fromrear by motoe mount T together then run longer hose up front. Quote
AKheathen Posted November 23, 2010 Report Posted November 23, 2010 um, lol...yah that's one of the 2 case vents..........it shoud be T'd to the rear vent, and the line going up by the rad, so water doesn't get in there. you can just plug that one if you really want. my dd cover doesn't even have one there. do not mix them up with the coolant hoses... Quote
