wakullabanshee Posted November 20, 2010 Report Posted November 20, 2010 If i try cranking it in gear with clutch in the banshee goes forward but if it in neutral its fine. This is my first banshee so any help would be thankful. Thanks James. Quote
87custom Posted November 20, 2010 Report Posted November 20, 2010 If i try cranking it in gear with clutch in the banshee goes forward but if it in neutral its fine. This is my first banshee so any help would be thankful. Thanks James. Ger a pancake bearing form vetos http://www.vitosperformance.com/atv_parts/product.php?productid=11515&cat=184&page=1 Quote
wakullabanshee Posted November 20, 2010 Author Report Posted November 20, 2010 One more thing if I let it warm up its fine. Quote
TwistedSheeRida Posted November 20, 2010 Report Posted November 20, 2010 Do you have a clymers manual yet? Sounds like the clutch is just out of adjustment, if you have a manual it wll take you through the steps, your going to have to order up some clutch cover gaskets so i would get those first then pull the cover. Quote
Josh Z Posted November 22, 2010 Report Posted November 22, 2010 One more thing if I let it warm up its fine. or you could be running too thick of oil in your trans. drain it and run atf and change it a little more often. Quote
