frog Posted November 19, 2010 Report Posted November 19, 2010 I installed a set of keihin pwk 33 carbs with original needles.What needles are best for dunning and hillclimb.My elevation is 950 and temp is 70 degrees and cpi inframe pipes with hjr dune porting and v-force 3 reeds 21cc domes.Jetting is 155 main with 45 pilots needles on third clip 40:1 klots oil with 93 octane gas.It's almost perfect just a little hesitat from 1\4 to half throttle.I tried raising needle no effect.I was told to change needles just want to know what needles you guys recomend.Thanks again this site rocks. Quote
rdzbangshee Posted November 19, 2010 Report Posted November 19, 2010 I installed a set of keihin pwk 33 carbs with original needles.What needles are best for dunning and hillclimb.My elevation is 950 and temp is 70 degrees and cpi inframe pipes with hjr dune porting and v-force 3 reeds 21cc domes.Jetting is 155 main with 45 pilots needles on third clip 40:1 klots oil with 93 octane gas.It's almost perfect just a little hesitat from 1\4 to half throttle.I tried raising needle no effect.I was told to change needles just want to know what needles you guys recomend.Thanks again this site rocks. I'm running a dek 2Nd clip and going to try my cel on the 3rd clip got to get rid of the hesitant power in the freezing cold Quote
frog Posted November 22, 2010 Author Report Posted November 22, 2010 I'm running a dek 2Nd clip and going to try my cel on the 3rd clip got to get rid of the hesitant power in the freezing cold Thanks I installed the cel needles on the second clip.The plug is finally burning a golden brown instead of black.You would think it would run lean on the second clip ,but the hesitant is gone for now.Thanks once again. Quote
