Artv Posted November 16, 2010 Report Posted November 16, 2010 In Glamis this past weekend and i let my Nephew ride the Banshee.. He said the bike just shut off, now the bike wont start and the kickstart is stuck.. Is this bad??? Quote
So Cal Suspension Posted November 16, 2010 Report Posted November 16, 2010 In Glamis this past weekend and i let my Nephew ride the Banshee.. He said the bike just shut off, now the bike wont start and the kickstart is stuck.. Is this bad??? Yeah, I would suggest pulling the head off and see what the inside of the cylinders look like. Might be time for a complete rebuild. It could be the bottom end also... Quote
Artv Posted November 16, 2010 Author Report Posted November 16, 2010 Yeah, I would suggest pulling the head off and see what the inside of the cylinders look like. Might be time for a complete rebuild. It could be the bottom end also... Damn it! I just had the top end done seven months ago.. The bike has no more then one hour on it since they did the top end.. Quote
So Cal Suspension Posted November 16, 2010 Report Posted November 16, 2010 Damn it! I just had the top end done seven months ago.. The bike has no more then one hour on it since they did the top end.. What were you running your premix at? If you put the bike in 3rd gear, and try to roll it, does the motor turn over? or it's locked up that way too? Quote
So Cal Suspension Posted November 16, 2010 Report Posted November 16, 2010 What were you running your premix at? If you put the bike in 3rd gear, and try to roll it, does the motor turn over? or it's locked up that way too? By chance, was this on halloween weekend? and it locked up at the bottom of Olds? Quote
Artv Posted November 16, 2010 Author Report Posted November 16, 2010 What were you running your premix at? If you put the bike in 3rd gear, and try to roll it, does the motor turn over? or it's locked up that way too? I was running the fuel @ 36/1.. Its locked up in third too. The bike wont roll in any gear Quote
Artv Posted November 16, 2010 Author Report Posted November 16, 2010 I was running the fuel @ 36/1.. Its locked up in third too. The bike wont roll in any gear It happen last weekend off of Gecko... Quote
So Cal Suspension Posted November 16, 2010 Report Posted November 16, 2010 It happen last weekend off of Gecko... Ouch, yeah... Time for a tear down, I think... Quote
12 0 Clock P I M P Posted November 16, 2010 Report Posted November 16, 2010 Ouch, yeah... Time for a tear down, I think... rod is lcked up on crank Quote
Larry's Shee Posted November 16, 2010 Report Posted November 16, 2010 Pull clutch cover off first. Could have problems in clutch or kick idler. Might save yourself some work. JMO, your results may vary. Quote
banshee67 Posted November 16, 2010 Report Posted November 16, 2010 sounds like it has seized up and pretty bad. Quote
Artv Posted November 18, 2010 Author Report Posted November 18, 2010 Thanks guys for the help!!! needs complete rebuild... Quote
Overboost Posted November 19, 2010 Report Posted November 19, 2010 hahah, that happened to me, just quit and kicker quit shattered the lower half of the piston that got shit locked in the crank and a no go. I rebuilt it with a 4mil yer shits hosed man Quote
