So my buddy has an 05 .. with Toomey T5's.. cool heads. probably has 10 hours on it... never rides it.. bought new...Well this year he decided to bring it out but is running into a few problems.. Drained all the fuel ..took apart the carbs.. new plugs.. it takes like 20 kicks... then its real sluggish ...then it will run really good and fast..then bog down really low...and this goes on and on... fowling plugs also.. he seems to think it is a float bowl issue because it is leaking a signifigant amount of gas frome the carb tube on the left side under the quad from the overflow tube.. please help!!!!!!
yeah id say stuck float..... that was happening on my buddy's blaster. took the bowls off, sprayed some carb cleaner.... good as new
thanks... well give it a shot... i hope thats all.. it cant be much... i guess thats what happens when you let em sit and not ride....
