bounty banshee Posted October 28, 2010 Report Share Posted October 28, 2010 (edited) at wide open throttle falls on its face but i noticed one plug is real wet other plug not so wet like im loosing a cylinder at wide open throttle but if i let off and go half trottle picks back up Edited October 28, 2010 by bounty banshee Quote Link to comment Share on other sites More sharing options...
06specialedition Posted October 28, 2010 Report Share Posted October 28, 2010 Air leak? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted October 28, 2010 Report Share Posted October 28, 2010 Change plugs, change plug wires (swap from side to side) Clean the carbs. If that doesn't do it...start looking electrical. Are you SURE the carbs are synchronized? Quote Link to comment Share on other sites More sharing options...
bounty banshee Posted October 29, 2010 Author Report Share Posted October 29, 2010 swap boots and see if the problem swaps cylinders. i did switched spark plug boots to other side and it does switch cylinders so could the coil be bad Quote Link to comment Share on other sites More sharing options...
dajogejr Posted October 29, 2010 Report Share Posted October 29, 2010 Before you buy a new coil, get NGK plug end caps, remove the stockers, trim back the wire a 1/2 inch and use the NGK ends. The stock banshee coil ends are known for going bad/loose/losing connection. Quote Link to comment Share on other sites More sharing options...
bounty banshee Posted October 29, 2010 Author Report Share Posted October 29, 2010 Change plugs, change plug wires (swap from side to side) Clean the carbs. If that doesn't do it...start looking electrical. Are you SURE the carbs are synchronized? yes i have a sync cuage Quote Link to comment Share on other sites More sharing options...
