too_fazt Posted October 26, 2010 Report Posted October 26, 2010 im messing around with the idea of doing a 4 mil now that i have my stock stroke built. i have vitos superstock pistons (the one with the recessed exhaust). would i be able to pull out the vitos and slap in the wiseco, or do they use diff tolerances. do i need to re bore my newly bored cylinders? thanks Quote
rdzbangshee Posted November 11, 2010 Report Posted November 11, 2010 my dumb brother rings were almost 1mm of he burnt up vito's pistons i told him he had a been crank but he sad ow it looks go he was wrong his old rings had a melt down they he rebuilt and had another on in no time Quote
dirtydownunder Posted November 11, 2010 Report Posted November 11, 2010 ok..... if the vitos are a cast piston, (i think they are) then you will have to bore the cylinders to fit the forged wiseco pistons in. forged pistons run greater clearances than cast. even if i were buying the same spec/brand piston, i would still get the bore and piston mic'ed up at a machine shop. Quote
J-Madd Posted November 16, 2010 Report Posted November 16, 2010 my dumb brother rings were almost 1mm of he burnt up vito's pistons i told him he had a been crank but he sad ow it looks go he was wrong his old rings had a melt down they he rebuilt and had another on in no time Huh??? You should be able call Vitos and get the tolerances. If the bore is already matched to the pistons you have, it is likely that Vito's of the same size should work. But it never hurts to have the piston and cylinder mic'd to be safe. The new Vito's pistons are forged and of good quality (imo); even though they're from Taiwan. Quote
J-Madd Posted November 16, 2010 Report Posted November 16, 2010 Huh??? You should be able call Vitos and get the tolerances. If the bore is already matched to the pistons you have, it is likely that Vito's of the same size should work. But it never hurts to have the piston and cylinder mic'd to be safe. The new Vito's pistons are forged and of good quality (imo); even though they're from Taiwan. I meant the Wiseco of the same size as Vito's should work (re read and realized your going from Vito's to Wiseco.) Quote
too_fazt Posted November 17, 2010 Author Report Posted November 17, 2010 nevermind this post...i remembered after i posted that wiseco makes the vitos i have. Quote
