bansheemann420 Posted October 12, 2010 Report Posted October 12, 2010 (edited) not too sure what happened went riding started smoking badddd and it still started up idled and ran until i took it apart of course when i took it apart the rings just fell off into like 6 pieces anyone with some knowledge thanks Edited October 12, 2010 by bansheemann420 Quote
Phelps Posted October 12, 2010 Report Posted October 12, 2010 lean=heat and lack of coolant, or coolant flow=heat. you have already taken it apart, so i would just go ahead and rebuild it. when you get it back together do a leakdown and check the water impeller. if it's a stock plastic impeller it may be in several pieces depending how old the bike is. Quote
AKheathen Posted October 12, 2010 Report Posted October 12, 2010 definately see ring snagging on both, and deto on the one. did you gap the rings? check bore clearance? looks kinda lean, too. a lot of baked-on oil. could have been oil separatoin, air leak, or simply jetting. did you account for cooling temps? need more info Quote
bansheemann420 Posted October 13, 2010 Author Report Posted October 13, 2010 (edited) not too sure on this one its a buddy of mines idk really anything about who did the work before. basically a problem that was rigged and handed down Edited October 13, 2010 by bansheemann420 Quote
