not too sure what happened went riding started smoking badddd and it still started up idled and ran until i took it apart of course when i took it apart the rings just fell off into like 6 pieces
anyone with some knowledge thanks
Edited by bansheemann420
lean=heat and lack of coolant, or coolant flow=heat. you have already taken it apart, so i would just go ahead and rebuild it. when you get it back together do a leakdown and check the water impeller. if it's a stock plastic impeller it may be in several pieces depending how old the bike is.
definately see ring snagging on both, and deto on the one. did you gap the rings? check bore clearance? looks kinda lean, too. a lot of baked-on oil. could have been oil separatoin, air leak, or simply jetting. did you account for cooling temps? need more info
