I have a 350 on akly, hardened basket, 8 plate set up, pancake bearing, running f type oil. When I pull the clutch in, the bike won't disengage, it just keeps on pulling. I tried changing oil, cable, springs. Nothing seems to help the situation. I adjusted everything in and out and still nothing. What exactly am I missing here? Or is there something that happened to the innerhub, pressure plate and basket that i can't see?
Did you soak the fibers before they were installed? The clutch arm and the pointer on the case lined up? Are you getting enough travel in the cable when you pull the clutch/ are you using the stock clutch lever?
