I just got a 2001 Banshee that someone put a 94 motor in it. He never finished hooking everything up. I noticed that the plugs on the wires coming from the stator are different than the plug on the CDI box. Both plugs have the same colored wires. I have the female plug that matches the one on the CDI box so that everything will plug together if I switch out the plug on the stator wires.
Does anyone know if the plug end is the only difference or will I have other problems trying to use the 2001 CDI nox with the Stator from the 94 motor?
Thanks for the help in advance
