Ok guys, whats ur experience with higher hp motor's shifting under wide open throttle? Mine hate's me shifting her at wot! What can i do to this tranny?
It shifts fine when you let off the throttle quickly between shifts??
You can override 1-4, 1-5, 2-4 or 2-5 on the trans. 6th gear from what I understand is in the process of being able to get included. You start out taking off just like any other trans. When upshifting you just shift the lever and it changes gears. No clutch slipping and no lag. It generally improves ET's a couple of tenths. The best thing to do is find another set of tranny gears to modify and keep the originals to put back in if you want. It is "usually" a drag race mod only.
The process of overriding a gear stack is to cut ramps on the dogs to where the gear is basically sucked into position when shifted. They are fully dunable as long as you think about it and ride it how they are supposed to. They shift like butter! once you ride one you'll never go back to a stocker.
Think carefully before jumping into it.
What motor and set up do you use right now?
Shifts fine when i shift it like a mack truck! Who likes that!
Thanks! some great info, its a 7mil set up with a ton of torque. The tranny really binds under load.
