just bought toomey t5 pipes for my 05 pretty much completely stock banshee only thing done to it is k&n filter which was like 40$ other than that when i replaced pistons and rings i went with weisco pistons and rings but my problem is i dont know what to do about jetting any input would be much help i want to run with the lid off ...... i dont know where to get the jets what sizes to get to buy the full jet kit ???
This is pinned at the top of this sub forum. Lots of setups just like yours through it.
Have a peek. http://bansheehq.com/forums/index.php?showtopic=99361
Pull a carb bowl off and see what mains and pilots you have, then unscrew the carb cap and check what needle you have and the clip position.
Then go from there. It's really REALLY easy.
stock pilot (25)
air screw 1.5 turns out from lightly seated
300 main
needle clip on 4th groove from the top
^^^ I bet thats pretty flippin close ^^^
:cheers:
stock pilot (25)
300 main
:cheers:
x2...might not even have to touch the needle though. try it first with the 300's and your air screw adjusted.. I was running t5's, K&N with no lid, and was running 300's at sea level.
you can buy the jey kit from toomey. it is a perfect jet kit for a pipe only bike. get their needles for the carbs to, they are a noticeable gain and get you even closer with your jetting
stock pilot (25)
300 main
:cheers:
when you say 300 main isnt the banshee twin carbs so it would be 2 300 mains>?
Are you running the Lid?
What is the Elevation?
What is the Temps you are running in?
What are in the carbs now?
no not going to run the lid about 2000ft elevation bout 60 degrees right now stock jets in carbs now ... where is the cheapest place to buy single jets
Just contact a site sponsor. I would look at getting 27.5 pilots. Mains jets from 280-330 This will cover you if you go to higher/lower elevations and major temp changes as well.
