this isn't a walkthrough but basically the end result. you need to follow the plug chop steps, then cut the threaded section of the plug away so you can see the center, very carefully using a hacksaw or dremel. i removed the whole thing just to see if it was consistent all around, cuz sometimes it's not and you need to go a little bigger on the mains. get a stock of plugs because obviously it destroys the new plugs, but a few dollars in plugs is well worth it vs. engine failure. this is basically what you're looking for, about a 2mm light chocolate colored smoke ring
ahh i got it now.... thanks alot for the pik..
