c1poweredeg
c1poweredeg's Achievements
  1. im located in Staten Island ny i have a brand new still sealed in the box gopro helmet complete kit . i bought it for 299i. im looking for 200$ i dont have pictures online but have them on my phone please txt 347-729-9736 thanks
  2. what is it that needs to be done? u need to take the end of the old boot and put it on to the new automottive wire ?
  3. iv heard of this mod that u use a 8mm automotive plug wire, to replace the stock plug wire with the resister ? does it actually help ? and does it work ?
  4. i just started running Klotz super techniplate.. in my shee.. my question is for 2 gallons of gas im mixing in 40:1 ratio ? does that sound correct ? am i running to little or too much 2stroke oil with the gas ?
  5. whats goin on man.. where in staten island are you.. i was looking for a rolling chassis cause mines tweaked. i am also located in stat.
  6. where can i buy jets for a good price.. for my 28mm pwks ?? let me know thanks HQ
  7. ok update i got the bike back. i kick it over..check the thumba adjuster and i also checked the height of the cables goin into the top of the carbs. and there all ok.. but in order for me to shut the bike down or get decent idle i gotta cover both carbs but while just hovering over the mouths of the carbs my hands get soaked with fuel. any ideas ??
  8. Thanks everyone ...I will try it out tommrow on the adjustments...tommrow when I get my bike bak
  9. I was told to be able to slide a dime between the cable and adjuster... is that correct?
  10. What's up hq another jetting and carb question. Ok before when I installed the new parts on to te shee... it was 28mm pwks 148 and 48 jets,vforce 3 reeds,new intake boots and new clamps. After kicking the bike over 2 times it would start but idle really high, so I thought I had a leak, I resealed everything but the bike still idles high as hell setting on the adustment screw are to spec and then some after some tweaking . But I still can't get the bike to idle correctly . Do you think it could be the jets ? I livee on statenisland if anyone is close leave me ur info. Thanks a lot
  11. im gonna try it tommrow see if this works..
  12. what s up hq...would anyone kno why my shees idle races after 28mm carbs and vforce 3 reeds are installed.my jets are 148 and 48. Gaskets werent used for the reeds,gasket sealer was used.when I put my hand over the carbs the idle the idle goes down a bit but still high,if I spray brKe cleaner it goes down on the idle. But as of right now im stumped.amy ideas hq?
  13. whats up HQ.. im looken for some plastics in decent condition.. let me kno what you have, i have seen people sellen them on here for for about 70 and up ..message me with some pictures. im located in staten island , ny
  14. ahh i got it now.... thanks alot for the pik..
  15. someone on the site told me about plug chopping and how it's done. still kinda catching some brain farts on it, does anyone have a picture of what is done? thanks..BHQ
