c1poweredeg Posted September 29, 2010 Report Posted September 29, 2010 someone on the site told me about plug chopping and how it's done. still kinda catching some brain farts on it, does anyone have a picture of what is done? thanks..BHQ Quote
MILO Posted September 30, 2010 Report Posted September 30, 2010 this isn't a walkthrough but basically the end result. you need to follow the plug chop steps, then cut the threaded section of the plug away so you can see the center, very carefully using a hacksaw or dremel. i removed the whole thing just to see if it was consistent all around, cuz sometimes it's not and you need to go a little bigger on the mains. get a stock of plugs because obviously it destroys the new plugs, but a few dollars in plugs is well worth it vs. engine failure. this is basically what you're looking for, about a 2mm light chocolate colored smoke ring Quote
c1poweredeg Posted September 30, 2010 Author Report Posted September 30, 2010 this isn't a walkthrough but basically the end result. you need to follow the plug chop steps, then cut the threaded section of the plug away so you can see the center, very carefully using a hacksaw or dremel. i removed the whole thing just to see if it was consistent all around, cuz sometimes it's not and you need to go a little bigger on the mains. get a stock of plugs because obviously it destroys the new plugs, but a few dollars in plugs is well worth it vs. engine failure. this is basically what you're looking for, about a 2mm light chocolate colored smoke ring ahh i got it now.... thanks alot for the pik.. Quote
