sp1tekiller Posted September 25, 2010 Report Posted September 25, 2010 Any quick fix tips for a Banshee choke not staying out? Quote
So Cal Suspension Posted September 25, 2010 Report Posted September 25, 2010 Any quick fix tips for a Banshee choke not staying out? Hold it out... In all seriousness, it's not a quick fix. I've never had that part of the stock carbs apart, but I believe there is a small spring-loaded ball-type-thing in there that holds it out. Either the spring is worn out, or there's a bunch of crud inside there not allowing the ball to drop down into the little slot on the choke-shaft-thing-a-ma-jigger. Get it? lol. Quote
sp1tekiller Posted September 25, 2010 Author Report Posted September 25, 2010 Haha okay, thanks for the reply. Quote
Overboost Posted September 25, 2010 Report Posted September 25, 2010 another quick fix, buy a new one and put it in there is a spring that drops in a grove on the shaft and thats what holds it out, that spring is broke or weak. no fix. except, holding it out, or replacing it Quote
Vintage Smoke Posted September 25, 2010 Report Posted September 25, 2010 In a pinch a clothes pin can work. Quote
kidthunder Posted September 28, 2010 Report Posted September 28, 2010 In a pinch a clothes pin can work. yeah just get a new one. i just ordered e new choke assembly 35.00 Quote
madjimmax Posted September 28, 2010 Report Posted September 28, 2010 I bought a new choke from the stealership and I thought it was less then $20 and they had it in stock. A blaster has the same one if this helps. Quote
MILO Posted September 28, 2010 Report Posted September 28, 2010 another quick fix, buy a new one and put it in there is a spring that drops in a grove on the shaft and thats what holds it out, that spring is broke or weak. no fix. except, holding it out, or replacing it agreed.. Quote
