12 inch wheels on a banshee
Budd
those are pimp... Haven't seen a set of those for ever
I have 2 sets of 12s for my golf cart... One set is Douglas lite cast with 25" Trail Tires for the street/dirt. They are effin heavy.. over 35lbs at each corner at least. The other is my sand set up... 12 Douglas .125 aluminums with 26x12x12 triple buff haulers... and bead to bead buffed fronts. They weigh less than a 20" molded paddle mounted on a ITP Aluminum wheel. I have 20x10x9 sand stars in my garage that are heavier than the 26" x 12 superbuff rear with 7 paddles.
The .125 12" douglas would be the way to go... As the rubber weighs more than wheel, you could theoretically have a lighter sand tire set up with 12's?
