Jtw Posted September 22, 2010 Author Report Posted September 22, 2010 Check to make sure there is a CEL needle in the slide,if not get two,there a leaner needle than supplied with the the carb and work well,also 38 pilot is the leanest pilot they make for the pwks.I would try the leaner needles first,plus they sell a vacuum guage for syncing carbs,Call jeff from fast numbers in my sig he can hook you up with everything including jetting info ok its weird that you say the lowest pilot i can go is 38, i was able to find 35's here locally, maybe a diffrent brand, any ways i still have no luck. 1/8-1/4 throttle still hesitates then opens up like crazy. oh well, looks like im gonna order a cel needle like you suggested and do a leak down test as well. my plugs are black again, and im fed up with this two stroke. also, had a quick question? not sure if i have after market reeds or not but should they have a plastic insert in them, thanks again? Quote
