bansheeboi Posted September 16, 2010 Report Posted September 16, 2010 OKAY YALL THIS IS WHAT I HAVE WHEN I BROUGHT MY BIKE IT WAS ALL OVER THE PLACE BUT GOT MOST OF THE STUFF TO REBUILD THE BIKE OK THATS COOL I DONT MIND THAT BUT THIS IS THE THING IM FACED WITH NOW MY JUGS ARE RUSTED IN THE INSIDE SO I CANT GET TO RIGHT SIZE TO ORDER MY PISTON I TOOK THEM TO A SHOP AN THIS NUT TELLS ME TO JUST ORDER SOME PISTONS AN I WILL HORNE AN BORE THEM OUT COOL BUT HOW DO YOU KNOW WHAT SIZE TO ORDER HE SAY I DONT JUST ORDER ANY SIZE DUDE IM NOT ORDER A PAIR OF PISTONS AND I DONT KNOW THE RIGHT SIZE TO ORDER I DONT WANT TO ORDER SOME THAT TURNS OUT TO BE TO SMALL THEN IM STUCK WITH THEM SO MY QUESTION IS HOW OR WHAT DO I DO TO CLEAN THEM OUT ON THE INSIDE TO GET THE RIGHT SIZE TO ORDER? MAN THEY LOOK LIKE THEY BEEN SITTIING THE BACK OF HIS GARAGE FOR YEARS AND AFTER I GET THE PISTONS WELL THE RIGHT SIZE TO ORDER WHO DOES A REALLY GOOD PORT JOB ON THE EAST COAST MAYBE EVEN SOMEONE CLOSE TO GA OR FLA LOOKING FOR AN AGGRESSIVE TRAIL PORT WITH ADDED BOOST PORTS? I GOT MORE BUT I WILL WAIT TILL I FINISH THIS PART OF MY MOTOR BEFORE MOVING ON TO THE NEXT TOPIC THANKS Quote
MattBerghauser Posted September 16, 2010 Report Posted September 16, 2010 (edited) Holy. what did I ever do to you to? Edited September 16, 2010 by MattBerghauser Quote
Phelps Posted September 16, 2010 Report Posted September 16, 2010 WHY ARE WE SCREAMING?! send the cylinders in to a sponsor and let them do their job. do not order pistons, you will only be risking losing/wasting money on a set they may, or may not fit/work. Quote
ECshee Posted September 16, 2010 Report Posted September 16, 2010 1. Enough with the CAPS LOCK....your not yelling, and we can read it regularly sized. 2. You need to have some use a micrometer to measure the inside of your cylinders. Should be [64.something]...Then decide how much your going to take out of the jug itself(bore out to the next size). You WILL need to order pistons, to the corresponding size up from your existing bore, to match your new bore. But any good machine shop SHOULDNT punch out the jug before they have pistons to match, as to check ring gap clearance. Realistically, you could just send your jugs off to a site sponsor, have them bore, hone, any porting you want done....and set you up with a topend package deal. Hope ya got some bucks though.... Just cost me damn near $500 just to bore and replace the topend. Factor in another 250-400 for porting, and youve got yourself a $1k topend. Quote
AKheathen Posted September 16, 2010 Report Posted September 16, 2010 actually, it is going to need to be punched out untill all the rust pitting is gone, and then a little more, probably, to get to the first useable size. it would be best to go with a builder that already has pistons on hand to match the bore, so you don't have to wait to find out what size you need. Quote
