SheeMonster Posted September 12, 2010 Report Share Posted September 12, 2010 Hi guys, Looking for some recommendations for gearing. Current Mods: 421 Stage 2 Cub Motor - All parts from Kevin Herr - Should be in the 90HP range. Cut Trans - no override - Still a 6 speed. Looking to run a +4 swinger. 20 tires (8 paddle Hauler) I only have the 8 paddle as an option in the hauler with a 9 inch rim. Riding Types: sand, trail and hill climbing. I am not lookiing for a drag setup for the sand (may play a little with a drag or two but not my main interest). Any advise would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
Pasi S. Posted September 13, 2010 Report Share Posted September 13, 2010 I would start with stock 14/41 and see how it goes. I think you have enough power to pull 15/41 or 15/40. I have 14/41 with my 20x11-10 8 V-padlle Sand Sharks and I think I´m going a little lower gearing like 13/42 and test it. I don´t know how much I have power but I think it´s between 45 and 55. -Pasi S. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted September 13, 2010 Report Share Posted September 13, 2010 Hi guys, Looking for some recommendations for gearing. Current Mods: 421 Stage 2 Cub Motor - All parts from Kevin Herr - Should be in the 90HP range. Cut Trans - no override - Still a 6 speed. Looking to run a +4 swinger. 20 tires (8 paddle Hauler) I only have the 8 paddle as an option in the hauler with a 9 inch rim. Riding Types: sand, trail and hill climbing. I am not lookiing for a drag setup for the sand (may play a little with a drag or two but not my main interest). Any advise would be appreciated. Thanks. 15/41 or 15/40 should be fine, imo. YOu need some more tire (paddle and roll out). Quote Link to comment Share on other sites More sharing options...
Sandfrk33 Posted September 14, 2010 Report Share Posted September 14, 2010 Sprockets are cheap, try a few and see what feels right. I have a 4 mil stock cylinder hjr dune port. I ride nothing but sand with 15/40 and pull it just fine. I weigh 240 lbs too. Cub should have no problem with taller gearing Quote Link to comment Share on other sites More sharing options...
