yeah 160 is up there! what size domes did you buy for the head?!
If the problem didn't move and you have good compression on both sides then that leaves fuel or spark, swap your spark plugs now to see if the problem moves, if it does then you have a fouled/bad plug.. if it doesen't move you've probably got something going on with that other carb.
but before you do any more testing be sure you verify your compression and read the PSI and not some other scale. If you're really at 160 PSI and not running race gas get whatever fuel you have in it now out and go find some race gas. If you don't wish to run race gas you're going to need to lower the compression probably by switching the domes out.
also i put a modquad head and 21cc domes in with the delta force reeds
Edited by Banshee Racer32
