nope....you only bore out the cylinder walls themselves. The best way to do it is to take your cylinders to a shop and have them mic the bore. Then they can tell you what the correct up-sized pistons to buy........most of us here will advise you to purchase wiesco pistons as they are some of the best. THEN BEFORE they bore it.....take them the pistons. This way they can exactly mic the new pistons and then actually bore the cylinders to the correct size. ALSO make sure that they have the knowledge to chamfer the ports so the rings don't snag and break.
