Nutwood 472 Posted August 21, 2010 Report Posted August 21, 2010 x2. if you connected them together and it made absolutely no difference, then they were already shorting together in the first place. go to the back of the bike, and snip the green/yellow wire. it should start frvving pretty normal. however, i suggest pulling the carbs and cleaning/rejetting them. make sure the float bowl with the little brass bead on the outside goes bacl on the left (choke) carb, and the little hose goes back on. putting aftermarket pipes on without jetting will melt your motor down. X2 on that,LOL I would eliminate that mess frist,before I would tinker with anything else. Quote
janlamarche Posted August 22, 2010 Author Report Posted August 22, 2010 thanks for the input guys, It was the parking brake wire all along.. I ran it all weekend and it's just screaming so now everything is perfect Quote
