I was riding this past weekend and missed third gear pretty hard on the shee. When I was riding back to the truck I went to pull the clutch lever and I had no tension. I know I need to pull the clutch cover off to see exactly whats wrong but just wanted to see if you guys have a idea of what it may be before I dig into this thing
It's the same feeling i had when i welded my ball to the shaft. banghead
Pull the clutch cover off to see what is wrong. Worse case scenario, time to split the cases. bangheadbanghead
Great time for a pancake bearing no matter what is wrong.
Edited by RagunCajun
Once you figure it out let me know..I have the same issue. There is absolutely nothing there when i pull the clutch lever
