stephenshane237 Posted August 15, 2010 Report Posted August 15, 2010 Need help on where to start for jetting stock bore shee, dual stage reeds, pods, stock bore, fmf fattys are the mods just got a set of prejetted pwks and they are off quite a bit. jets installed currently are 55 pilots, 155 mains N68a needle middle clip. I have low end bogging and wot bog if nailed at lower rpms top end runs great. Need to know a good place to start for pilots and mains, also n68a needle or CEL, JJH ? sorry i ride in OHIO for elevation Quote
lykins89shee Posted August 15, 2010 Report Posted August 15, 2010 I'm in Dayton OH with 28pwks. I run 152 mains 50 pilot n68a needle middle clip. I still think im a little fat on my pilot could probably drop to 48. You will probably in up around 150mains 48pilots or so, but i would check your plugs and go down one size at a time. Quote
stephenshane237 Posted August 15, 2010 Author Report Posted August 15, 2010 I'm in Dayton OH with 28pwks. I run 152 mains 50 pilot n68a needle middle clip. I still think im a little fat on my pilot could probably drop to 48. You will probably in up around 150mains 48pilots or so, but i would check your plugs and go down one size at a time. thanks for the response i was thinking the pilot and main were way to rich for this bike i will get some jets and see if that works. Quote
T_Shee Posted August 15, 2010 Report Posted August 15, 2010 with stock jugs you will prolly wind up around 148 ish and 45 to 48 pilot should be ok. i ran the n68a needles but didnt really notice difference from others. or buy my dune ported jugs and leave the 155s in Quote
stephenshane237 Posted August 15, 2010 Author Report Posted August 15, 2010 with stock jugs you will prolly wind up around 148 ish and 45 to 48 pilot should be ok. i ran the n68a needles but didnt really notice difference from others. or buy my dune ported jugs and leave the 155s in lol i just seen the pics, i am building an hjr 4 mil this winter but my top end is gone need to decide whether to go with your jugs just for the rest of the summer or not Quote
