what's up? I am have problem with banshee. when i get it started and looking at the back it looks like the lift side ( look at it from th back) is not running right. When i put my hand up to the exhaust i don't fill the pressure or the pop like the other has. Hope you can help.
replace your plugs should clean your cars and get then in sync last check your compression
My son's 'shee had simular problem when he bought it . Ended up pulling flwheel with the proper pulller , cleaning poles on stator , inside of flywheel , nubs on outside (for pick-up) , and setting pick-up gap , .016-.018 or thickness of business card. Could also be plug boots , resistor inside goes bad . Also swap plug wires to see if problem switches also.
Ditto, the first thing i would do is swap plug wires to see if the problem changes sides. if it does then it's electrical, if not then it's mechanical...
