CTxBanshee Posted August 10, 2010 Report Posted August 10, 2010 Hey i was just wondering about dome sizes with the cool head. What size would be lowest that you could run pump gas on. Race gas is kinda far away from me so I want to use pump gas when i need to but also have the option of use Race fuel. Quote
So Cal Suspension Posted August 10, 2010 Report Posted August 10, 2010 Hey i was just wondering about dome sizes with the cool head. What size would be lowest that you could run pump gas on. Race gas is kinda far away from me so I want to use pump gas when i need to but also have the option of use Race fuel. It will vary depending on what your elevation is. Generally speaking, I have heard you can run as low as 19's on pump gas, if you are at a high elevation. Sea level to about 1500 feet or so, I wouldn't go less than 20's. Just my two cents. Quote
madjimmax Posted August 10, 2010 Report Posted August 10, 2010 It will vary depending on what your elevation is. Generally speaking, I have heard you can run as low as 19's on pump gas, if you are at a high elevation. Sea level to about 1500 feet or so, I wouldn't go less than 20's. Just my two cents. X2 on that Quote
CTxBanshee Posted August 10, 2010 Author Report Posted August 10, 2010 Well a map that I just looked at said I was 600-1200ft above sea level soo.. Quote
So Cal Suspension Posted August 10, 2010 Report Posted August 10, 2010 Well a map that I just looked at said I was 600-1200ft above sea level soo.. ...soooo.... Sea level to about 1500 feet or so, I wouldn't go less than 20's. Just my two cents. Quote
EvilBanshee Posted August 10, 2010 Report Posted August 10, 2010 if i were you i would get 22's. i just did the worked out the compression ratio on my 421 with the 22's. its at 11.6:1, and i run 103 octaine. you should be running minimum 94 with compression like that. Quote
Burt Reynolds Posted August 10, 2010 Report Posted August 10, 2010 I had a bike that ran pump with 20cc domes,and i had a bike that needed 100 octane with 21cc domes, Quote
atvaddict Posted August 12, 2010 Report Posted August 12, 2010 how do you figure out what octane gas is required for your mods and dome sizes??? For example i have a stroker crank, carbon fiber reeds and spacers, milled head(don't know how much), k&n, +4 timing. (All mods were done by previous owner) He told me to run 110 octane minimum. I have a cool head and 19cc domes new just laying around. Just wondering what octane i would have to use if i put the cool head on. Quote
someone82 Posted August 12, 2010 Report Posted August 12, 2010 http://www.sacoriver.net/~red/uccr.html Quote
sandman81 Posted August 12, 2010 Report Posted August 12, 2010 Ran 18 on stock banshee with bolt ons. reeds, adjustable timing plate set at 4, pods, and t6 pipes. elevation 2389 feet. Quote
atvaddict Posted August 13, 2010 Report Posted August 13, 2010 Wow! Thanks to someone82 for all that info. Extremely helpful but way out of my league. Problem is i don’t know much about this motor bc i bought it like this. Im just going to leave the milled stock head on and sell the coolhead head. Quote
