hey ppl was thinking about gettig a 15t front are they ok im looking for more speed got beat by 2 shee last weekend lol dont wanna loose again
I run 15t on both of my bikes. Works great for a little extra speed. If you have a case saver, make sure it will accept a larger sprocket.
ok cool so it does give more speed? are there any down falls like not as fast off the start or anything
As long as you have the power to pull it, I haven't noticed any issues. Plus you can pull each gear a little longer. Cheap mod, play around with different sizes to see what you like.
ok nice ill try it thanks
Well what kind of race was if? One to see who Has more mph?
With a 15t front u will accelerate slower making your bike not as quick in a drag race. But yeah you will get more mph in each gear and all the gears will last a Little lOnger.
yea it was to see whos bike was faster overall and they both beat me by like 2 quad lenghts lol it sux
15t should be fine for that. Don't go to a 16t on a non ported motor, though. It takes it a long long way to top out (if it even will.)
Then that would be a no on who has more mph since it was by two lengths and no X amount of mph.
Set up can go a long way. Gettting off the line better can make up a couple lengths on the big end if it's to a set distance like 300 feet.
I personally wouldnt go with a 15t front unless you have smaller than 20" tires. But hell, sprockets are cheap, cant hurt to try it :headbang:
ok so when you two crossed the finish line were you keeping up with him......like as in were you two going roughly the same speed but he was 2 bikes ahead? or was he still pulling away from you hard when you crossed the finish line?
is he a smaller guy than you?
what mods do you have? and what did he have?
if you were goin roughly the same speed but he got you outta the hole then setup can DEFINTAELY help you with that...
When we used to race like that, you just basically kept going until it stopped pulling. Whoever was ahead then was the winner. NO skill involved in that way. Hole shot didn't matter much; just seeing which bike was the fastest (not necessarily quickest.) That sounds like what he is doing also.
i bought my quad recently an it had 15/39.. it only pulld after the middle of 3 but moooved after that . i had some sprokets laying around so i put 13/41 on it lastnight.. anyone run the same ? i could use some help with other shat to if anyone if interested in givein me some advise
well he was a good distance away from me when we crossed but i have t5s vf3 reeds vitos power stock pistons thats all he had t6s dont know about reeds and a 4 mill crank which is wat i think the reason he was so much faster
