banshee1988 Posted August 8, 2010 Report Posted August 8, 2010 i have a 07 banshee that is Piped, K&N Air Filter with Stock Lid, Barnett Clutch Kit, Boyesen power reeds & 0.0030 over Wiseco Pistons the elevation is 700 feet above sea level, all i need to know is what size main jets to use, what size pilot jet, how much to turn the air/fuel mixture screw, & what position on the jet needle the clip should be? any help would be greatly appreciated Quote
SAVAGE420 Posted August 8, 2010 Report Posted August 8, 2010 http://bansheehq.com/forums/index.php?showtopic=99361 At the top of this sub forum. ^^^ Probably 50+ guys with the same set up, have a look through the pages. Stock carbs? What pipes? Holes in the lid? Temps up in FT Simpson? Quote
madjimmax Posted August 8, 2010 Report Posted August 8, 2010 Any after market pipes requires a 27.5 pilot and as far as mains I would start with around a 300 and do a plug chop from there. All bikes are different and its hard to give a specific size someone can get you close, but you will need to do a plug chop to be safe.This is assuming you have stock carbs Quote
banshee1988 Posted August 9, 2010 Author Report Posted August 9, 2010 http://bansheehq.com/forums/index.php?showtopic=99361 At the top of this sub forum. ^^^ Probably 50+ guys with the same set up, have a look through the pages. Stock carbs? What pipes? Holes in the lid? Temps up in FT Simpson? it has stock carbs, fmf fatties with powercore2 sliencers, no holes in the lid, how do you know i'm from the N.W.T? i think i got it figured out today though, i went with 220 main jets & it cured the problem i hope, just got to ride it a little more to know for sure! Quote
ionroller Posted August 15, 2010 Report Posted August 15, 2010 220 will be lean as hell im at a 290 with same setup but no snorkel on lid... unless ur in a mountian Quote
