kfx700 Posted August 6, 2010 Report Posted August 6, 2010 when i lock the parking brake nothing happens im thinking its jus a broken cable...but is there a common problem that happens to them..I new to the banshee thing so i jus trying to learn...thanks for the help Quote
ELKARACING_SHEE Posted August 6, 2010 Report Posted August 6, 2010 when i lock the parking brake nothing happens im thinking its jus a broken cable...but is there a common problem that happens to them..I new to the banshee thing so i jus trying to learn...thanks for the help the parking brake on the banshee's never works, its time for a block of parking brake plate Quote
mitty8251 Posted August 7, 2010 Report Posted August 7, 2010 make sure the cable is adjusted correctly. Most of the time the pin in the brake caliper freezes up Quote
Jereme6655 Posted August 7, 2010 Report Posted August 7, 2010 i think ive only seen like 2 or 3 shee's that still have the parking brake on them... Quote
shee2000 Posted August 7, 2010 Report Posted August 7, 2010 (edited) parking brake block off plate Edited August 7, 2010 by shee2000 Quote
GrMeyer Posted August 7, 2010 Report Posted August 7, 2010 parking brake block off plate 1x They never work and if you want them to work. Then you area always adj the cable. I have 6 other bikes that I just say for get it and let the bike just sit in 1st gear. Then If the bike/s start moving. Then I know there is a leak going on. Quote
