252wheelieking Posted August 4, 2010 Report Posted August 4, 2010 Can anybody give me any suggestion to what causes antifreeze to flow out my overflow hoses under hard acceleration. When I stop, my radiator make this boiling noise when I shut off my engine. I removed my coolhead & install new head gasket with stock head & the samething happen. All help is highly accepted! Quote
brugal Posted August 5, 2010 Report Posted August 5, 2010 Can anybody give me any suggestion to what causes antifreeze to flow out my overflow hoses under hard acceleration. When I stop, my radiator make this boiling noise when I shut off my engine. I removed my coolhead & install new head gasket with stock head & the samething happen. All help is highly accepted! A lean condition can cause overheating. How do your plugs look? Quote
firebanshee Posted August 5, 2010 Report Posted August 5, 2010 Check your impeller,do you have good coolant flow when you rev the engine with rad cap off? Quote
