every once in a while i will get a little steam off my right pipe for just a second and dont know where it was coming from,
the other day it happened again and i stopped fast and looked and it looked green coming from a black hose behind radiator, behind gas tank, looks like a vent
any help???
thanks
it may be on the edge of over heating. it's the puke tube. what kind of impeller you running? stock style, or billet? if it's a plastic one i would check to make sure it is still in one peice. if you ride in the mud alot i would make sure the radiator is clean. gotta remember it's hot as hell out just about anywhere and they will just puke a little when ridden hard.
would a oversize radiator help
a billet impeller is the best choice and almost every sponsor here can get you one. stock cylinders? what is the bore? the only reason i would just all of a sudden start leaking is either a head gasket, the impeller lost a fin, or two, or the radiator is full of mud, or it's just damn hot outside and you haven't rode it in this heat before.
Mine spits if I fill the resi over half full. Its just hot as hell out. Billet impeller will help.
:cheers:
Yup, don't overfill and get the billet impellar. Heat does wonders to fluid levels and plastic impellars.
