99bansheeworked Posted July 27, 2010 Report Posted July 27, 2010 hey guys another question what is the domes is it the cover where the piston are? also i see 16cc dome 17 and 18 what the difference? do you need more parts to put a bigger cc on and does it do anything Quote
Phelps Posted July 27, 2010 Report Posted July 27, 2010 domes are changeable combustion chambers in aftermarket heads. the smaller the number the more compression you will end up with. not something you want to guess at. a site sponsor can help you chose the right cc's for your application. Quote
Jereme6655 Posted July 27, 2010 Report Posted July 27, 2010 hey guys another question what is the domes is it the cover where the piston are? also i see 16cc dome 17 and 18 what the difference? do you need more parts to put a bigger cc on and does it do anything a dome is what fits inside of a aftermarket performance head....such as a coolhead or a FAST perofrmance head. they are heads that allow different cc combustion chambers to be put in and changed for more compression per cylinder equalling more power. 16, 17, 18 and so on are the cc of the domes. in order to run a smaller dome (meaning less space for same amount of fuel/air equaling more compression) you have to do other things such as run higher octane fuel or even race gas once your compression gets too high. otherwise your bike go boom... Quote
Phelps Posted July 27, 2010 Report Posted July 27, 2010 damn phelps....beat me to it haha only i didn't have to type as much lol Quote
