diablo Posted July 26, 2010 Report Posted July 26, 2010 Hey Guy's I need some help. I have a 2001 Banshee, with FMF pipes, Boost Bottle, K&N pro flow kit, Twist Throlltle, Jetted to 260 main and 30 Pilot. I just had the complete engine rebult crank too. Removed T.O.R.S., completely(left &right unit, throttle switch, unit), completely rebuild the carb. My problem is that it starts good but the right side gets hot really fast but the left side seems to run at 50%. I get some white smoke on the left when I throttle up. I did noticed that the left carb started to leak fuel from the over flow. I already sinq the carb. I ordered a replacement fuel valve for the leak. When I put my hand on the silencer I get little pressure coming out of the left pipe. HELP ASAP. Quote
jaybanshee Posted August 6, 2010 Report Posted August 6, 2010 Diablo... Did you ever find out what your problem was? I seem to be having the same issue. Quote
TNTS355 Posted August 6, 2010 Report Posted August 6, 2010 check your flywheel and pickup distance Quote
jaybanshee Posted August 6, 2010 Report Posted August 6, 2010 check your flywheel and pickup distance So even if you have fire... this could still be the problem? Quote
pr0blumz Posted August 7, 2010 Report Posted August 7, 2010 Reeds on that side could be bad also. Quote
TNTS355 Posted August 7, 2010 Report Posted August 7, 2010 So even if you have fire... this could still be the problem? I have had a flywheel nut back off and they flywheel worked loose and lost fire on one side. Quote
