hey i just blew a piston on the right side a first i thought it was a plug because it was only running on one cylinder so i shut it down and unscrewed the right plug first and it was white . put my thumb on the hole and crank it over by hand to see if the compression was there and on the second crank it wouldnt turn no more . so ill be taking it apart very soon to see what happened in there . what could of cause one cylinder to be running very lean . ill keep you up to date when i tear it down . thx in advance
ok here is a litle update of where im at after tearing it down i found a broken piston skirt on the intake side of the right cylinder .I retrieve a small piece of the skirt in the base which was stoping it from turning there wasnt any obvious signs of an air leak . a sligtly torn boot but not all the way trough . the right piston has a litlle more slack in the cylinder than the other one 0.005 mm to be exact i believe that is the limit on the left side it was closer to 0.004 . could a lean condition break a piston skirt or was it the slack that could of cause it .
hope someone can help me out dont know if i throw new pistons in or go one size bigger in the cylinder im already at 0.020 over
thx
You need to mic cylinders to measure out of round and taper. Skirt probably broke from piston slap . IMO, tolerances would have to be less than half before I'd just put new slugs in. The biggest cost will be pistons, gaskets , bout 3-350. Cyl bore maybe 100. You might also have to split cases to remove all debrei , if you do use new crank seals, 20. JMHO, your results may vary. Btw, piston oversizes are in .010 increments, unless you have bad gouges, you should be able to go .030 oversize, still leaves you five more overbore sizes to go.
Edited by Larry's Shee
http://cgi.ebay.com/ebaymotors/YAMAHA-YFM350-BANSHEE-TOP-END-KIT-CYLINDER-BORING-/320539852991?cmd=ViewItem&pt=Motors_ATV_Parts_Accessories&hash=item4aa1aa00bf . Decent deal right here. Have dealt with Mike on several different bikes. Lakes Motorsports , Waterford ,Mich
ok seem like a good deal but i have a 4mil stroker kit so it wouldnt be the same pistons right ...thx for the advice i think im gonna go the safer way and bore it out to 0.030
