way2cool101 Posted May 25, 2010 Report Share Posted May 25, 2010 hi guys, im new to this forum..... ok so i just got this 93' banshee, and it seems like its runnin/riding kinda weired... when you start off in first gear it kinda hesitates, but as you start speeding up, lets say 2nd or 3rd gear, it gets better and starts riding like it should.... so, i was wondering what could be causing this problem? maybe i need to get new pistons? or adjust the carbs? maybe i need new spark plugs? i just got this banshee today, so i havent worked on it yet.... i got it cuz it was cheap, and im planning on rebuilding the whole thing in the winter.... any advise would be great.... Quote Link to comment Share on other sites More sharing options...
pr0blumz Posted May 25, 2010 Report Share Posted May 25, 2010 hi guys, im new to this forum..... ok so i just got this 93' banshee, and it seems like its runnin/riding kinda weired... when you start off in first gear it kinda hesitates, but as you start speeding up, lets say 2nd or 3rd gear, it gets better and starts riding like it should.... so, i was wondering what could be causing this problem? maybe i need to get new pistons? or adjust the carbs? maybe i need new spark plugs? i just got this banshee today, so i havent worked on it yet.... i got it cuz it was cheap, and im planning on rebuilding the whole thing in the winter.... any advise would be great.... Could be a number of things. What is your jetting? Quote Link to comment Share on other sites More sharing options...
way2cool101 Posted May 25, 2010 Author Report Share Posted May 25, 2010 Could be a number of things. What is your jetting? i have no idea...... how do i check it? Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted May 25, 2010 Report Share Posted May 25, 2010 pull the carb out from the intake boot and pull the four screws from the bottom of the bowl. Look at the mid of the bottom of the carb for the Hex nut. It should have 3 numbers on there. IE (240). Read up on this site. http://www.dfn.com/benkaren/jetfaq.html Quote Link to comment Share on other sites More sharing options...
way2cool101 Posted May 25, 2010 Author Report Share Posted May 25, 2010 (edited) pull the carb out from the intake boot and pull the four screws from the bottom of the bowl. Look at the mid of the bottom of the carb for the Hex nut. It should have 3 numbers on there. IE (240). Read up on this site. http://www.dfn.com/benkaren/jetfaq.html thanks. ill try do do that tomorrow, and maybe clean the carbs as well...... im assuming it is stock (200), cuz the guy i got it from didnt do anything to it, other than the pipes and boost bottle.... Edited May 25, 2010 by way2cool101 Quote Link to comment Share on other sites More sharing options...
