nutting741 Posted May 20, 2010 Report Posted May 20, 2010 hey im sorry if this is a question that is commonly asked and i didnt dig deep enough but any help will be greatly appreciate. ok i bent a connecting rod on my banshee and when i took off the head and cylinder walls i cant tell if the top end has been rebuilt before i was told to look on top the pistons at the numbers so i did and the only numbers i could read were 4690c the others were covered under the carbon so does any know what these numbers mean? thanks Quote
nutting741 Posted May 20, 2010 Author Report Posted May 20, 2010 i have no clue man when i bought the banshee i was told it was stock and never been rebuilt Quote
Larry's Shee Posted May 20, 2010 Report Posted May 20, 2010 Need to clean it better, use some carb or brake clean and a scotch brite pad. Dont be to aggressive you'll wipe out numbers. Quote
nutting741 Posted May 21, 2010 Author Report Posted May 21, 2010 ok so just clean it up and what will the numbers under the carbon tell me? Quote
Larry's Shee Posted May 21, 2010 Report Posted May 21, 2010 With the number off the top someone smarter than me will be able to identify them for you. That's how I was able to determine I had Wiesco Blaster style 1st overbore. Quote
nutting741 Posted May 23, 2010 Author Report Posted May 23, 2010 ok thank you and one last question i am at 4900 ft above sea level do you have any idea what jets i should be using for that and it also has fmf gold series pipes and v force III reids in it and do you know the stock length of the connecting rods Quote
elev8ted Posted June 5, 2010 Report Posted June 5, 2010 ok thank you and one last question i am at 4900 ft above sea level do you have any idea what jets i should be using for that and it also has fmf gold series pipes and v force III reids in it and do you know the stock length of the connecting rods I have a ported and polished banshee with v-force reeds, k&n pods and t-5s and run a 360 main, raised the needle 1 clip and a 35 pilot. I am at 2000 feet. The rule of thumb is to reduce 1 size jet for every 500 feet of elevation if that helps Quote
