bansheemann420 Posted May 18, 2010 Report Posted May 18, 2010 (edited) how can i remove the sensor in my throttle and the tors w/o taking the tops off Edited May 18, 2010 by bansheemann420 Quote
alf44 Posted May 18, 2010 Report Posted May 18, 2010 Just get the kit and do it right. It comes with new tops, drill and tap, idle screws, new cable and very simple instructions. I can get it to your door for $59 Quote
chrisp250r Posted May 18, 2010 Report Posted May 18, 2010 yeah and if youre scared to drill and tap then you dont even have to do it, the engine will just die if you dont give it any fuel... which isnt all bad, it will save you alot of spark plugs Quote
AKheathen Posted May 18, 2010 Report Posted May 18, 2010 you can unplug the little box next to the coil to disable it, but you will run into issues with the intakes cracking from the weight, throttle sticking when they get wet, 100x the headache jetting, etc, etc..... Quote
