I just got my carbs synced now I can't get it to idle. I took it for test ride n I noticed there was a miss in the bottom end. I have the tors removed
Are you sure the tors are properly bypassed?
It is very important that you sync your carbs without any idle set in or this could affect the way you perceive the balance of left and right.
is this a problem that occured with the addition of the TORS removal or have you upgraded something else also. or has this problem just occured when you synced your carbs?
