shakenbake1285 Posted May 17, 2010 Report Posted May 17, 2010 I just got my carbs synced now I can't get it to idle. I took it for test ride n I noticed there was a miss in the bottom end. I have the tors removed Quote
blowit Posted May 17, 2010 Report Posted May 17, 2010 I just got my carbs synced now I can't get it to idle. I took it for test ride n I noticed there was a miss in the bottom end. I have the tors removed Are you sure the tors are properly bypassed? It is very important that you sync your carbs without any idle set in or this could affect the way you perceive the balance of left and right. Quote
Jereme6655 Posted May 17, 2010 Report Posted May 17, 2010 I just got my carbs synced now I can't get it to idle. I took it for test ride n I noticed there was a miss in the bottom end. I have the tors removed is this a problem that occured with the addition of the TORS removal or have you upgraded something else also. or has this problem just occured when you synced your carbs? Quote
shakenbake1285 Posted May 17, 2010 Author Report Posted May 17, 2010 Started after the carbs got synced Quote
shakenbake1285 Posted May 17, 2010 Author Report Posted May 17, 2010 100% posative tors r bypassed right Quote
shakenbake1285 Posted May 17, 2010 Author Report Posted May 17, 2010 I don't think I had the idle screws all the way in when I synced the carbs Quote
shakenbake1285 Posted May 18, 2010 Author Report Posted May 18, 2010 What should I do or check to fix it Quote
