this isnt my banshee its my friends, hes also like 265lbs. he runs a open air box and he says plugs are white, maybe too lean?
If the plugs are white, it's lean as hell. Do not run it, until it's rejetted richer. Start with a 350, and see how it works.
I would pull the needles and nozzles out, and run at least a 370 main jet in it to start. You need to make sure it has the right components in it first.
im havin the same problem. i have the vm 28 round slde mikuni carbs and the bottom is awesome all the way up too about 3/4 throttla then it sucks. i have put every jet from 310 too 390 and moved the clip too every spot and it still does it. whats up guys. mods are in my sig
