jay shafer Posted May 15, 2010 Report Posted May 15, 2010 16mm cheetah, 74.5mm bore 39mm alky carbs, 7 degrees timing, egq needle middle clip, from the what the other cylinder look like we was spot on with the jetting but something major happen on that left side. piston seized in the cylinder and wrist pin gone broken b/c the crank tried to keep moving while it was seized. This was done after 3 runs a purge and then one more run about 2 hours later. The last run was after the purge. It wasnt really a run it only moved 3-5 ft after i got the purge gas out and the alky was flowing to the carbs. pics are here http://s985.photobucket.com/albums/ae331/jayshafer16/ and the video thats on photobucket is the how it was after i brought it back out from being purged for about 3 hours Excuse the photographer he shaky as hell All three runs http://www.youtube.c...h?v=gi6flQcLFMU http://www.youtube.c...h?v=tHwDNIGbwuA http://www.youtube.c...h?v=lNEmPu0TkDc After the 3rd run it was purged and put up for about 2 hours and then all hell broke loose!!! Any input would help!!!! Thanks Quote
