blanco25 Posted May 13, 2010 Report Posted May 13, 2010 How much fuel is flowed with a duel pingle gravity feed compared to a alky mikuni pump? Is there that much difference? How many people run the pumps? I do alot of hillshooting and drag racing and just want to make sure im going the right route. I already have the chariot oversized billet bowl and the dual pingle but someone told me the hill at little sahara utah is probably going to need a pump. And to be just be on the safe side and not to run the bowls dry. Any and all input would be appreciated thanks. Quote
Boston Posted May 13, 2010 Report Posted May 13, 2010 i personally dont run one but i know that alot of people do run them here in utah for sand mountain. seen them on just about every bike even the 4mil cubs. im in the process of building a hillshooter and ill be running one just to be on the safe side. Quote
Koolguyson Posted May 13, 2010 Report Posted May 13, 2010 No reason not to run a pump. Of course you should be running one. Depending on your motor you "may" not need one. But is it worth gambling your weekend and top end on? Course not. Quote
sheefreak Posted May 13, 2010 Report Posted May 13, 2010 Beside the obvious added insurance of a pump it will also prevent you from ever accidentally hydro locking your motor. If your billet bowls have an overflow, shouldn't be a problem though. Quote
No Limit Powersports Posted May 13, 2010 Report Posted May 13, 2010 The fuel system is one place i like to tell people to overbuild a pump is very cheap insurance. Can you get by without it, probably but why wouldnt you just want the peace of mind knowing that your safe. Quote
blanco25 Posted May 13, 2010 Author Report Posted May 13, 2010 (edited) Im noticing that all the pumps only have 1 inlet and then 2 outlets. So it was a waste to get the dual pingle? I guess ill just get some cover for the other outlet on the pingle. Thats why i was wondering about the pump vs the dual pingle. Because with dual pingle you have two gravity feed outlets, and the pump you only have 1 inlet trying to flow out through two outlets. I didnt know if it could flow more fuel or its was just a cheaper route than billet bowls. Edited May 13, 2010 by blanco25 Quote
sheefreak Posted May 13, 2010 Report Posted May 13, 2010 I would run both outputs of your pingle to a T. The input to the pump is 5/16 so get a T w/a 5/16 output. It will provide more than enough fuel that way. Quote
dajogejr Posted May 14, 2010 Report Posted May 14, 2010 I run billet bowls AND a pump on my bike, and I only run 300 feet. Overkill...sure. But I know fuel delivery will never be a problem, it allows me to concentrate on other things. Pumps are cheap too...the big, high volume DF62 (Black Mikuni Pentagon type) is around 60 bones and flows up to 65L per hour. The other pumps are half price and flow 30 to 35L per hour... Quote
J-Madd Posted May 14, 2010 Report Posted May 14, 2010 300 ft = no need for a pump on most engines, imo. I'd say gravity is fine up to 610 cc for sure. After that, you may need a pump. For hill shooting or racing any farther than 300 ft, I'd say a pump is a good idea. Even for 300 ft racing, it won't hurt anything and is inexpensive (as mentioned.) Quote
Koolguyson Posted May 18, 2010 Report Posted May 18, 2010 You can actually add an input and an output on the hex pumps. I have to run two pumps and two oversized cast bowls (bigger than the billet bowls) on my 760 in 300 feet. Otherwise there is not enough fuel supply. Quote
