Stroker81 Posted May 12, 2010 Report Posted May 12, 2010 Anyone have any ideas what this could be. It will cut out when I turn the bars far left and right. I still have parking brake on think that would have anything to do with it? I am clueless. Quote
bbcmudtruck Posted May 12, 2010 Report Posted May 12, 2010 Check to make sure you don't have any wires touching the frame anywhere causing it to ground out. Also eliminate any TORS or parking brake wires you have. Quote
DallasGDub Posted May 12, 2010 Report Posted May 12, 2010 Check to make sure you don't have any wires touching the frame anywhere causing it to ground out. Also eliminate any TORS or parking brake wires you have. what ryan said. A lot of wires and stuff in the front under the bars. The bars could be pushing something together that is not supposed to touch. That would be a good place to start to eliminate and move on to other possibilities. Quote
baker Posted May 12, 2010 Report Posted May 12, 2010 ill tell ya right now what it is, its the plug that comes from your key switch that goes to the main harness. mine was doing the same thing, take off the gas tank and locate the plug ill bet its got a loose wire in it. set the tank on sideways fire it up and pull on the wires going into the plug from the key switch, it will cut out figure what wire is loose and cut it and hardwire it to the coresponding wire it would connect to in the plug, or wliminate the whole plug and wire them all direct, i had this happen on a couple of my shees and everyone swore up and down it was the tors or the ebrake cable. let us know if this was the problem Quote
